Freakrider
X247
- Tampa Bay area
Yeah thanks, all three stator coils were ruined by bendix weights inside the flywheel...A big thanks to sj762 for hooking me up again with parts....Had a blast wrenching in the garage today while perfect sunny day going on in the low 70's .Your not alone , It happened to me on the beach at Waverave 2013 and it was no fun wrenching in the hot sun, in the sand, scrounging for parts in august ! Im glad you can fix it before the ride ... no tiime was wasted , have fun
Damn glad we rode then! What caused it?
Used Oem bendix unknown hours. Bendix weights end up inside magnetic flywheel and then shred the stator coils.Normally the retaining spring wears through and breaks, it is a wear item and should be replaced every season. How much time was on that bendix?
Totally dry inside...I have never had a bendix grenade and always use oem. Have had the retaining spring wear and break before. Need this core bendix ? I can bring it...water intrusion?
Thanks for the education on the bendix Chris!
Can that plate be replaced if that happens?
Chris is right, it's a PITA. I've replaced a handful of them in a pinch, making one out of two. I always order another from the maniac at that point though just to be safe. I've seen several with the missing ear syndrome.Thanks for the education on the bendix Chris!
