- sunbury ,ohio
Electrical Issue Update
To back up a bit I compared my charging voltage12.7 against my purple blaster 13.5V and this one is not charging !! so thanks SUPERJETT for the charging voltage info. My question is : How do you test a charging/lighting '' stator'' coil ??? I have disconnected the regulator due to it showing a charge of ''0-1 volt'' ''Test done per manual procedures '' NOW ........ There are 2 green leads coming off the stator coil, should I test it this way/ '' red V-METER lead to a green wire , black V-M lead to the other green wire "" Or Red V-M lead to one green wire and the Black V-M lead to ground ?? I have done it both ways and cant find a charge anywhere in those green wires !! It does not say how to do this in the test procedures that I can find ???
