I like that idea, but I'm not sure about it. Removable pieces of hull doesn't sit well with me.
I know extensions are used like this and have proven to be durable, but if I'm buying an aftermarket hull and spending the money, I hope someone can design a bottom deck/hull that is well rounded, I shouldn't have to change/remove extensions.
I guess it depends what you want. I personally don't care if I can flatwater backflip. I do care however if I can do it off a wake or roller.
So to me a shortened hull may not be the best, I'd rather have a boat that can do everything well instead of a few things "really" well.
Features I would want:
a) Still rides slightly nose high,
b) Has enough weight reduction to warrant the purchase (90-95lb. hull is max weight I think I'd want, anything more doesn't seem light enough, may as well work with an OEM topdeck, of WCF/XFT topdeck on a OEM bottom.)
c) Stronger than OEM (a given)
d) Better looking design (although I'm digging Butti's hull over and above everything else AM, so maybe not)
e) Perhaps an option to mount the 66E platform (WDK hulls). But this would be my last request. A 62T built motor will haul my light arse well enough. I'll never need more than a stock stroke motor. If I find I do, my technique isn't good enough.
Its all about what you want to do with the boat. No good answer.
RiverRat - The hull sits high and is very bouyant. Why wouldn't that be a blast in a freeride application? Getting jarred off wakes and rollers, skipping the hull in corners. The best part I like about standups is when they get all erratic. Thats what makes it fun & hard to get good at. I'm sure with the right weight distribution the boat will handle good enough. OEM tank, and regular weight battery. Bring the nose down a bit, but not too much:smile:
