Back Flushes
P
PancakePete
Guest
I have seen some cool flushes out there and I am wondering what you all use and what type and size fittings you need ?
I use the quick connect but It does not get the whole system !
Slut has an awesome one that hooks to hose and fits in the pissers outlets so the system gets a complete flush out.
What you got X Crew ?
SuperJETT
none
I flush from the pissers as well. I have a brass "high velocity" nozzle for the garden hose, the tip fits in a pisser just barely but enough to flush full pressure. My only problem right now is I'm running parallel cooling so I have to alternate between circuits (exhaust/engine).
I used to have a short piece of fuel line that went on the nozzle and had a 1/4" o.d. nipple in the end that would hold itself in the pisser.
Then again, I haven't really used it since moving from Hawaii..........
P
PancakePete
Guest
Thanks Jett. I will look for that Brass Fittings. and I have some 1/4" , just need to hook that up to the hose some how ?
SuperJETT
none
This one. In brass, stick a short piece of 1/4 line on the end and in the end of the 1/4" line a small sleeve or something that will fit in the end of your pissers. I also have an on/off valve on it so it's super easy to use.
P
PancakePete
Guest
Cool. Got the on/off. things.
I will see if I can find something like Dat ! :biggthumpup:
eschberg
Boycotting Winter.
San Marcos, TX
Ive never ridden in the ocean, therefore never had use for a flush kit... and im having trouble picturing one... can someone post a picture of this 3-way thing while it is in use?
im going to galveston next month and i need to make me one for the trip.
WaveDemon
Not Dead - Notable Member
Hell, Florida
I don't have a pic but it looks like the single in Jett's post but with 3 hoses. you push each end into the 3 pissers. Most people don't have 3 pissers and don't need the 3 way model.
SJBrit
Extraordinary Alien
Bradenton, FL
WaHoo_1 said:
Yup, a MUST. Make sure it's running BEFORE comencing with flushing procedures!
And switch the water off before you switch the motor off. Never have water running without the motor running....
