b pipe manifold
tubbs
X-
uk
is it just me or are the top two middle bolts on manifold a bitch to tighten up i noticed my manifold was leaking slightly so striped it down cleaned it put a new gasket on AND I JUST CAN NOT TIGHTEN THE TOP TWO MIDDLE ONES ENOUGH:banghead::banghead::banghead::banghead: :banghead: so its still leaking a bit more now imo :banghead::banghead::banghead:
is there any special way you guys tighten up yours
cheers grant
oxnard111
Creative RE Purchasing
cheers grant
Could the threads on the suspect bolts holes be stripped? :dunno: Just a suggestion.
butti
lone wolf
F-XTC
its a wicked pita.you can only tighten them maybe 1/16th of a turn at a time.be patient and just keep fliping the wrench.you can grind the wrench and the manifold for a little more clearance too but dont expect a miracle.
#ZERO
Beach Bum
Florida - U.S.A.
Install the exhaust gasket with those two bolts pre-mounted because the b-pipe manifold has a cutout for those bolts. Then find an old 12mm open end wrench and grind the outer edges for more clearance. Secure those two bolts snug before tightening the rest of them to the manifold.
tubbs
X-
uk
well tried grinding a 13mm (mine are 13s) open ended wrench and it didnt work dammit probably ground to much off as it wouldnt grip it:banghead: try another tomorrow as i can hear couple of pints calling me:woot: you can see the water clearly come from the bolt area and i can only assume its through it not being tight enough
any ways going to run it like it sunday as i can not be arsed to drain the tank to remove the tank to get the chamber out to get at the manifold:banghead:
