- knoxville,tn
Mods this year.
66e with wdk wet pipe.
Home made motor mounts.
Cart Tank.
Gas valves.
Wdk girdle heads.
Fresh paint.
more to come.
Part 1.
aint
I started off by stripping all the old paint using aircraft remover(bad idea it makes a mess)and sanding..
I'm down to the original coating.Im using base coat clear and paint I had left over from my previous job.Any way after way to many hours or should I say weeks of labor im almost done with the sanding paint and color sanding..
I used nason 2k primer wetsanded with 400.
Black ppg 9100.
Alsa corp blue emerald crazer.
Alsa corp cobalt blue candy concentrate in the final clearcoat.
I sprayed 2 coats of black base,4 heavy coats of clear.
Wet sanded with 1000 grit 2 days after clear was sprayed.
Followed by 1500 and then 2000 grit paper.
Last I buffed with 3m compound and then 3m swirl remover..
I rushed the and it shows in the clear..The fiberglass was a little un even,but its a stocker who cares...
The candy in the clear gives the effect of darker edges and depth.
The crazer shifts color from emerald to blue(small metal flake).
I used plastic wrap and an air gun for texture..
Cart Tank.
Gas valves.
Wdk girdle heads.
Fresh paint.
more to come.
Part 1.
Black ppg 9100.
