madscientist
chilling with these guys.
- good old p'cola
anyone ever repair their t/l pickup that was not working?
:stups:
:stups:
thanks i am not getting any contact between the wires when i pass a magnet over it.
does it need to be pwered up w/ 12v to get a contact? just trying to have everything right before the new motor goes in/\
The pickup will register a very small resistance if you pass the flywheel magnet over it.
thanks. i'll check it tonight hooked up to a battery. red-+, black - gnd, white will be output on the dyna pick up. how does the msd work. is it the same? it's in the motor already and hooked up but i am not getting a signal from it from what i can tell.
Well that ever so slight resistance increase when you pass it over the magnet was how I determined my static timing when the LED didn't work. I could only assume that if both wires were actually connected the resistance increase would be present.
Passing the magnet over the sensor induces a small amount of current into the sensor.
Because of the way a Voltmeter/Ohmmeter works, you read that as a higher resistance.
It's not actually higher resistance, but the meter thinks that it is.
