Other Anyone adjust seasonally ?
madscientist
chilling with these guys.
good old p'cola
i rode yesterday for the first time since the temp dropped here on last weekend. I found that after doing a few runs and the x2 was topping out and running a little to good, I did a plug check to find near white plugs. made a couple of adjustments and mocha-ed them up a little.
i can only attribute this to the cold air.
any thoughts? :cool:
I ride in quite different environment conditions depending on time of year.
It ranges from 110 degree weather (70 water) to 25 degree weather (32 degree water).
I've never had to adjust carbs for that.
The only thing I do is restrict my cooling depending on water temps.
I'd guess it depends on how finicky your carburetors are (or maybe how well tuned they are to begin with)
madscientist
good old p'cola
the only other variable was that i re-installed the drilled stock water box and removed the silencer that i was using in place of the box. ( much quieter now)
Mark44
Katie's Boss
100% one place
Yes of course, cold weather riding can require a carb adjustment and water restriction but then again most people set there carbs by feel and don't really know how well they are performing anyway.
Mark44
tor*p*do
Squarenose FTW
NW NC
I alway richen about a 1/4 - 1/2 turn in early and late season
when ambient temps drop, it is just like putting a cold air intake on a car
except there is no mass air flow sensor to adjust the mix
cold air is more dense so your f/a mix becomes lean as more oxygen per unit volume goes into the combustion chamber.
richen her up!
At the last Smith lake ride I had to richen up all three skis before they would run right.Were you not paying attention?
BC
up here in canada when the penguins migrate north and the beavers come out in the summer the water and air temps vary from skating on ice bergs to being able to use just a thick wet suit, I used to adjust my carb settings.... Just kidding... sometimes you dont need a wet suit.
Anyways I found the best solution for me was to make up a thermostat that controlled engine temp. That way if there is ice or hot water, my ski aways runs the same. An added bonus was I was able to run 3-4 jet sizes bigger.
More fuel = more power right? I have not had a cold seize since, and I would never take it off.
