Disclaimer... this particular plate seems to fit correctly but I cannot guarantee others will. Modify at your own risk!!
OK, it fits. Just to clarify it's a shredmaster ride plate for an SXR or 98 and later SXI Pro. I JB welded the original bolt holes and redrilled the holes 1/4" further out, then used a 1/2" bit for the recessed area, then a 1/2 forstner bit so I can use the factory style bolts. You really need a drill press for this, especially because the bits seek out the jb welded old holes versus the aluminum when drilling, but I did this as a low-buck mod and did a 1/2 arsed job by hand. Lesson learned? Drill press and aluminum welder would have helped
Everything seems to line up correcty and I test-fitted it last night. Today I prettied it up with a fresh coat of primer/paint and I plan to install tomorrow. Pics to follow!
Pretty stoked with this plate by the way. I hope it's is as good as it looks (shredmaster SXR plate, 18" long). Other plates may or may not fit. What seems to be the primary requirement is the ability to redrill 1/4" further out. Some plates don't have a thick metal mounting area further out (you need to have room for the bolt and shoulder).
