Any gueses?
You most likely could get by with cleaning the aluminum off the cylinder walls and install a new piston. Most importantly, make sure the combustion temps are cooler. Start by opening the top screws 3 turns, power should be down. Then slowly close them until response and power is adequate. The idea is to stay slightly rich of peak power, that is a lot rich of peak heat.
I agree, but since I have everything apart and there is mild scoring on the cylinder, I am going to bore everything 1mm over to be safe.
No need to go 1mm over if .5mm over will do the job. Just extra work with no gain and eliminating possible rebore in the future.
Ditto don't go any farther O/S than you need to go to clear the scoring and get the cylinder back round, if .25mm will do it then go .25mm .
You have to go several mm's before you realize any performance gains , Yamahas won't bore out that Far.
Send it to whoever is boring the cylinder and let them determine what needs to happen is my best suggestion.
701 will go out 3mm to 84mm which is the stock 760 bore size
32T cylinder has much thicker sleeves than the 61X cylinder does .
