- Akron, Ohio
I agree, but since I have everything apart and there is mild scoring on the cylinder, I am going to bore everything 1mm over to be safe.You most likely could get by with cleaning the aluminum off the cylinder walls and install a new piston. Most importantly, make sure the combustion temps are cooler. Start by opening the top screws 3 turns, power should be down. Then slowly close them until response and power is adequate. The idea is to stay slightly rich of peak power, that is a lot rich of peak heat.
