- WI
I bought this ski a few months ago and according to the seller, this ski "never takes on water because of the great hood and seal". One of a few big lies he sold me on this ski... So, after riding surf a number of times, I realized the current hood setup was not going to cut it. Every time I attempt any type of maneuver that places the nose in the water (e.g. stab), I end up ingesting water and the ski runs like crap until I change the plugs or get lucky and clear it out. I've slowly been addressing the problem, but haven't been able to solve it yet. I changed back to a stock flame arrestor (helped a bunch) and also replaced the junk home depot seal with a watcon hood seal. Problem is, I'm still sucking water. It's better, but not there yet. The bilge is constantly running after any good sub-type trick. I don't know the history of the hood, but the right side of the hood lip has been ground at a taper starting at the bow and increasing to the stern (see pic). There is compression of the seal all around, however it is very light in the area that it was ground. The other obvious entry way is through the pole cable hole. As of right now, the rubber boot is really just floating around the cables and not anchored in any significant way.
So my question is, how do I seal up this hood? I'm planning on glassing the area that was ground down, back in on the hood lip. I'm also considering blocking off of breather tube or two. Is it necessary to have all four? I also have intrusion when I sink the ski deep, a$$ first off a decent wave. I feel like that could be due to the proximity of the breather tube and FA (the tube terminates right in front of the FA opening). I'm at a loss on how to seal up the cable hole. How do you guys do it?
Any recommendations would be great! I'm sick of sucking water at every ride!
Pics to follow...
Pics to follow...
