New ADA Racing at JetManiac
JetManiac
Stoked
orlando
JetManiac is a master distributor of ADA Racing parts and we stock a large selection of ADA products for you.
ADA girdled and nongirdled heads for Yamaha 701/760/1100
index.php
ADA 701 billet domes $44.95
(37cc, 35cc, 34cc, 33cc, or 31cc)
ADA 760 billet domes $44.95
(40cc, 38cc, 36cc, or 35cc)
ADA girdled and nongirdled heads for Kawasaki 900/1100
ADA girdled and nongirdled heads for Kawasaki 650/750/800
ADA billet accessories in post 2
Under construction.....
JetManiac
Stoked
orlando
Throttle wheels
ADA billet throttle wheels $23.
(Orange, red, silver, black, blue, or green)
Bow eyes
ADA billet Standard length bow eye for Yamaha $12.
-in black, silver, red, or blue
-same fitting for front or rear
ADA billet long bow eye fitting $18.
(in black, silver, red, or blue)
-Perfect for trays with thick padding
ADA billet Standard length bow eye for Kawasaki $12.
Water bypass (Pissers)
ADA billet 45deg water bypass (pisser) 3/8" 12.
(silver, black, blue, red, orange or green)
ADA billet 90deg water bypass (pisser) 3/8" 12.
ADA billet straight water bypass (pisser) 3/8" 12.
(silver or black)
ADA billet 45deg black water bypass (pisser) 1/2" 15.
Bilge outlets
ADA Billet bilge outlet $15.
(black, silver, blue, red or orange in straight or 45 degree)
JetManiac
Stoked
orlando
ADA zero degree straight bars with crossbar and pad 54.90
ADA crossbar replacement pad 12.95
ADA billet driveline couplers 79.95
(Engine side and midshaft side couplers)
Dampener Kawi a/m for ADA couplers 22.
ADA Yamaha crank side coupler 39.95
ADA Yamaha midshaft side coupler 39.95
ADA couplers for Kawasaki
ADA billet coupler for Kawi 750 39.95
Billet aluminum drive coupler w/18mm threads. Uses stock Kawasaki 650/750 rubber damper. Clear anodized for protection against salt water corrosion.
ADA billet coupler for Kawi 800 39.95
Billet aluminum drive coupler w/20mm threads. Fits the Kawasaki 800 crank and drive shaft, also some larger 750 cranks. Uses stock Kawasaki 650/750/800 rubber damper. Clear anodized for protection against salt water corrosion.
ADA billet coupler set for Kawi 800 79.95
Billet aluminum drive coupler set. Uses stock Kawasaki 750/800 rubber dampner. Clear anodized for protection against salt water corrosion.
More coming....
JetManiac
Stoked
orlando
ADA SuperJet 38mm carb to flame arrestor adapter 16.95
**ADA Racing billet aluminum carb adaptor fit any standard flame arrestor with a 2-3/4 inch mounting diameter.
ADA 44mm carb to flame arrestor adapter 16.95
ADA 46mm carb to flame arrestor adapter 16.95
**ADA Racing billet aluminum carb adaptors fit any standard flame arrestor with a 2-3/4 inch mounting diameter. Fits Super BN Mikuni 4 bolt carbs. Includes mounting bolts.
ADA billet flame arrestor riser 14.95
25mm tall flame arrestor riser. 48mm inner diameter. These are sold individually and do NOT include bolts.
ADA billet Kawi 900/1100 carb to flame arrestor adapter 18.95
Flame arrestor adaptor for the stock Kawasaki 900('98 and earlier) and 1100ZXi('97 and earlier) carbs. These do NOT fit the newer CV style carbs. These adaptors are sold individually and include 2 6x110mm allen mounting bolts. 44mm diameter opening on adaptor.
index.php
Looking for girdle head for 760. Trying to get 215-225 compression
