A bunch of noob questions
Thought I'd start a thread for all the inevitable questions I'll have. Starting with that is this? I tried looking at a parts fiche but couldn't find it anywhere. I found it laying in the bottom of the engine bay. I assume it's part of a mount but don't know what for?
Sent from my SM-G925W8 using Tapatalk
Tyler Zane
Open Your Eyes
The top one looks like one of the rubber pads in the bottom of a battery tray. The other could be one of the pads under the tank or water box. Who knows.. Ive shoved anything and everything under a waterbox and gas tank for a little buffer against the hull.
When I found them they were right at the back near the driveshaft, I was just hoping they weren't something to do with how that passes through the hull. I was in the middle of nowhere for a week with no Internet or anything so I decided to ride anyways and I didn't notice any difference. I'm away at work but when I get home in a few days I'll try and take a better look at the battery and waterbox.
Forgot to mention the gas tank has the massive foam around it so I don't think it would be from there.
Another random question I have is how long does it normally take to get flow out of the pisser upon startup? Mine seems to take quite a while sometimes, and sometimes smokes a little after I shut the ski down. Is that just because the water lines are connected to the exhaust?
Vumad
Super Hero, with a cape!
St. Pete, FL
yes. My superjet with dual cooling flows immediately. My stock B1 takes about 30 seconds. If you have a stock exhaust, they dump loads of water into the exhaust path which takes longer for it to come out the pisser. You should always let a ski warm up before you stomp on it anyway. I idle about 1 minute, half throttle about 1 minute, just hit full throttle for a moment for about a minute. This lets the block and pistons warm up, the cooling lines clear out and any air in the fuel lines work through. After sitting on the shore, I only do the 3rd minute before jumping back in. The motor should be pretty warm and the fuel lines still well primed.
Ya I always warm it up by just cruising around first. I think I just didn't notice how long the pisser took to get flow the first few times I rode cause I was just focused on balancing. So then when I did notice I wasn't sure if it had always been that way or if something had changed.
