Big Kahuna
Administrator
- Tuscaloosa, AL
Did you check the compression on the 550 before you removed and installed the ADA?
was ~145 on my gaugeDid you check the compression on the 550 before you removed and installed the ADA?
Gauge variance is real. It's all fairly relativeI had a 91 550sx, Picked up a Westcoast head for it. Right before I started to remove it, I checked compression. Right at 170 lbs. Stock head, Gave the Westcoast back! Didnt see any need in swapping.
