Sorry for the long post but here goes. Ok this has been plaguing me for about 2 weeks now, I picked up a stock 91sj, ran fine took it for a test run and have put about an hour on it since I got it, as it is just starting to get nice out. I was ridding it memorial weekend took a rest, restarted it, hit the throttle and it died. Could get it to run with gas in the carb but not sucking fuel on its own. Changed fuel filter with a fram inline as I couldnt find the stock one anywhere in town. Ran great for a min then same thing that filter was clogged up. Drained the tank cleaned out, and rebuilt the carb the screen inside the carb was completely full and clogged I figured that was my issue. Now all back together and it will idle fine but if you give any throttle it dies. If you hold the choke down it will rev full throttle fine but smoke like hell . Tried turning out the high end to no avail.
Im thinking maybe the inline fram filters just dont have enough flow? I ordered a couple stock ones and am waiting on them. Just not sure what else it could be Ideas? Also what is good place to be on the stock hi low mixture both were set at 2 turns out when I started. Oh and 1 last thing there is no FA on it could this be an issue?
Thanks For any input
