kraqus
- Great State of Texas
I got a set of Blowsion Destroyers that I am trying to install. When I place the Tubbie on the side of the ski, I can see it makes contact on all its surface but I feel it should be a bit forward. The problem is when I do this the tip of the Tubbie detaches from the side of the hull and leaves a small gap. The Tubbies are solid and I don't think they will bend when I tighten the front screw. I am thinking to simply fill that gap with 5200, that should fix it, however I am not still sure if I should do this. If this is not clear I will post a picture of it.
How did you install yours?
Any feedback is appreciated.
Thanks!
Benny
Thanks!
Benny
