800 X2 pipe conversion
hi pipe pros
i'm thinking of getting a blaster limited pipe, but was wondering if you can weld up the end where the stinger is and put the outlet on the bottom as a centre bleed style, to make it fit, so it will look a bit like the sxr wet
here's what we ended up doing
put it in one of these, bolt one of these on the back, hope it works out
work till its late, no test ride, and then load up and go racing
tricky1
XXX
hi pipe pros
I have one also if you need another.
the thing was flying, rider says it was faster than his dry piped SXR with the same engine, but the head pipe to manifold bolts came loose, then the head pipe cracked at the mounting flange where the outer rear bolt goes through and couldn't finish the day
