If a 760 is what your looking for then just go buy a complete 760 for about 700.00. Yea Yea I know the 61X timing is suppose to hit harder on bottom but, I cant see you building a 61X bottom with a 62T top for less.
a big bore 61x cylinder will hit a lot harder off the bottom then a stock 760.
Question is, will it do so on 650 cases.
because I would have to find 61x cases in perfect condition and then find a manifold then pay to have them ported and would they really be that much better then the ported 6m6 cases?
As far as going with the 62t cases then the price really goes up.
plus intake manifold, and carbs, and filter setup. Before you know it you got $500 more into the project.62t cases generally only go for about $200.
I ws talking about when you said building a 61x with a 62T top for less. A 61x 760 top will hit a lot harder then a 62T bored to 760.Thats why I said what I did in RED.
Thanks.
yes you are right for around the same price. But like I said before this guys ski looks so nice it looks like it under warrenty still. So if I could use his old motor for the build I would like to do that. Also the group k big bore kit says it will outperform a stock 701 and come real close in power to a modified 701. For $880 thats not to bad.
