300/440/550 650sx help IN SC
tbaer
USMC
BEAUFORT SC
I am in beaufort sc and i need help tuning my 650 sx. I have a west coast pipe and mani, pjs waterbox, 38mm carb, mariner head. I can not get this thing to stay running, and if it does run it runs like crap. I also get no water from the pisser, but all the lines are clear. sometimes it backfires too. if anybody is in sc or tampa area in fl i will bring my ski to you and pay you to tune it. give me a call if you think you can help (843)476-9296 name is travis.
tbaer
USMC
BEAUFORT SC
thanks man i will look him up next time i am down there. i wish someone in sc could help me out and just swing by my place. I'LL SUPPLY THE BEER!!
tbaer
USMC
BEAUFORT SC
so i figured out that my 650 sx runs great when it is hooked up to the hose, but if it is in the water it runs like chit! water lines hooked up wrong????.... carb out of tune or what could it be?
CA
Wish I knew more to help ya out...
Check out PWCtoday.com....If you haven't already...seems like I get answers quicker there than I do here but both sites are good in their own way...good luck!
Kennay
Squarenose for the _____
Myrtle Beach, SC
I will be in charleston this weekend. How far away is Beaufort from Summerville?
And if you want it fixed bad enough to drive down to Little River, I will help you out with it no problem and no charge.
tbaer
USMC
BEAUFORT SC
I on on deployment to yuma arizona right now but when i get back i will look you guys up and we will see what we can do. pm some names and numbers and i will call when i get back. by the way i get back on oct 31
Sounds like possibly a compression issue too. Check that. You might have a bad head gasket forcing air into the water jacket area. This would explain no water out of the pisser and no power while in the water but better on the hose. Might also want to check your lines for blockage.
kawi440
Nick
Givhans, SC
Travis, I live in the walterboro area and i am more than willing to come and help out. Give me shout. 843-452-9221 I had the same problem with my 440 when i first put in my stroker.
kawi440
Nick
Givhans, SC
i sent you a pm. I dont actually live in walterboro. I wasn't really sure if you were familliar with sc all that well. I live in st. george. You can ride in the edisto in some areas right now, but water levels change and the river can go to as little as 1 and half feet. I usually ride in moncks corner on the lake or in the tail race. That is where I am originally from.
jsd
Nor-Cal
If it back fires you either have an air leak or lean carb.or timming issue
you should be running 44MM carb anyway.
650's are notorious for sheering the woodruff key and letting the flywheel go just alittle off, enough to cuase your symtoms. check that first.
thejetskidoctor stand up watercraf specialist for 20yrs. good luck if you have more questions hit me up on my site. pwcrider.com goto the ask the pro's section. i am on there alot as are a few of my other mechainic freinds. good luck
