N3vrSat1sfied
Military Member
- Fort Worth, TX
Sorry the quality taking with the cell phone but here is a pic. Its right at the Seem underneth the front bumber
put that 650 motor in an older js 550 hull that 650 is a great motor old reliable and in a 550 hull they are so much fun they are not race boat's but they are a blast for freestyle.
I totally agree. Those old 550 hulls were the "original" freestyle ski back in the day. The 650 was probably the biggest turd kawasaki made as far as a hull design. (IMO) If you have a built up 650 motor in a 550, you wont want to get rid of it even when you buy a SJ. Those skis are so much fun and so easy to throw around. Just ride the 650 as is, have some fun and save all your money for the SJ. Then part the thing out and throw that motor in a 550 hull and you'll have 2 bitchin skis!
hell if you have the 750 sx why would you want to put the money into the 650 sx anyhows?? build the 750 up and you will be fine !! many will say the 750sx isnt a good freestyle machine either but its gotta be a ton better than the 650. and there is more than one guy around here who do or have ran kawis with good results ....just my .02
air leak is causing the ski to run lean, causing it to run hotter than normal so the plugs get hot enough to ignite the fuel without spark.Why would my 650sx run at full throttle with out plug wires on it? I started it up and then reved it up just a little and the the engine just started screaming. i yanked off the plug wires and it just kept going. i had to rip the fuel line off of the carb to get it to stop.
