62t 760 cylinder boreing
looking to find someone that can port and bore my 760 62t set up. its a 64x motor. i have new pistons (85mm), so it needs to be bored out and i would like some more bottom end. so i guess im looking for a freestyle/freeride port if there is such a thing. whos good at doing this without spending a butt load?
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Our shop rate is $75 per hole for std .5mm over bore. If you are at STD 84mm bore now you would incur a extra boring pass of $4 each hole to over bore from 84mm up to 85mm.
You really can't lower port timing unless you machine the bottom of the cylinder to get great hit off the bottom.
The 760 64X cylinder can be a little flat off the bottom without a real aggressive engine setup.
chuck,
how much do you recommend be removed from the bottom?
i know you mentioned it one day but can't find that thread anymore.
i have a 61x cylinder that i will do a big bore to if i cant do my 62t set up for a decent price. im just trying to find a cheaper solution. im looking at about 500 to do my 61x set up.
LPW porting
Paul@ LPW/ jr magoos did my friends port job and the thing is tops. He just completed mine and I am looking forward to his work. He's super cool to deal with!! Give him a call...
I have heard great things about Supertune's shop as well:)
.i remember having this discussion a while back but couldn't remember the #.
either 55 or 85 thou but you've clarified it now.
thanks chuck.
