550 reed motor... viper 7000
i have a issue with constant water spraying out of my cylinders, i think it is in the crank case. is there any way to drain the crank case on this type of motor. i cant seem to find a way without pulling the motor.
the WaTeRhAwK
fryin' up a/m electrics..
okc
if you have constant water spraying out of your cylinders, it has to be getting in from the waterjackets. that usually means you have a leaky headgasket, or a cracked head, or cracked cylinder. water doesn't circulate through the cases.
