N3vrSat1sfied
Military Member
- Fort Worth, TX
Going by the dealers recommendation they told me it was important to hook up the trickle charger when not in use. Guess what, the dealer Macomb Powersports, was WRONG!
I trickle charge is a good ideal!!!! You just had a battery fail. Not sure if there is other stuff your not disclosing but a failed lead acid battery is not the fault of the dealer unless they forgot to fill it (which is part of the build and prep/uncrating). It is not uncommon for a low cost lead acid battery to fail. Get a nice AGM and use a battery tender you will get plenty of years of life.
