Super Jet 2014 Super Jet, start button makes clicking sound in Ebox.
N3vrSat1sfied
Military Member
Fort Worth, TX
Going by the dealers recommendation they told me it was important to hook up the trickle charger when not in use. Guess what, the dealer Macomb Powersports, was WRONG!
I trickle charge is a good ideal!!!! You just had a battery fail. Not sure if there is other stuff your not disclosing but a failed lead acid battery is not the fault of the dealer unless they forgot to fill it (which is part of the build and prep/uncrating). It is not uncommon for a low cost lead acid battery to fail. Get a nice AGM and use a battery tender you will get plenty of years of life.
OCD Solutions
Rentz, GA
Yuasa is far from junk, at least it hasn't been in the past. I have never been a fan of trickle charging myself. I have tried every charging method and every brand of battery over the years and still lost/lose batteries. I have had a Yuasa last for over seven years and a Deka fail in just 4 rides. Whatever the magic recipe is to making them last, it it still a mystery to me.
All I run now is Deka and just shop around to get them as cheap as possible. I use a small Schumacher charger to top them off the night before each ride.
You need a battery maintainer. A trickle charger will keep charging and charging. A maintainer will bring it up to a certain voltage then go to a "float" mode a hold it there. Check out Battery Tender brand. I keep mine on the my two skis when not in use and my batteries last a long long time.
Sent from my iPad using Tapatalk
