- Sacramento, CA
2012 "Green" Brawler Gen 2 Build
Did not have time to do a build thread for this ski, mainly because it was built in a week. However pictures were taken throughout the whole build. The ski went together very well with no problems or need for custom parts. All inserts were in the ski from Rage Composites and everything bolted in with no problems. The ski had a Ported 62t/62t 701 from Patch Motors. This was a bored motor to make the Daytona Free Ride.
The motor that will be put into the ski for the 2013 season I will talk about below.
Motor:
-62t/61x
-Ported by LPW
-Dual 38's
-ADA Head
-B-Pipe
-MSD Enhancer
Hull:
-2012 Brawler Gen 2
-Glass construction hull with kevlar reinforcement
-Weighed in at 90 lbs with hood.
-Full width ride plate, both surf length and flat water
-Custom rear side exhaust
-Cast pump shoe
-ATP scupper
-Worx scoop grate
-1/2" coolant lines
-Trim tube
-Reinforced nose
Pump:
-Yamaha 144 pump
-2008 OEM Prop
-Protec trim system
-Cold Fusion couplers
Handling/Steering:
-RRP Pole
-Blowsion pole pad
-RRP steering
-RRP riser bars
-RRP bar extensions
-Hand warmers
Hull picked up from Rage Composites.
Hull picked up from paint.
Pump shoe alignment and install by PATCH motors.
Motor:
-62t/61x
-Ported by LPW
-Dual 38's
-ADA Head
-B-Pipe
-MSD Enhancer
Hull:
-2012 Brawler Gen 2
-Cast pump shoe
-ATP scupper
-Worx scoop grate
-1/2" coolant lines
-Trim tube
-Reinforced nose
Pump:
-Yamaha 144 pump
-2008 OEM Prop
-Protec trim system
Handling/Steering:
-RRP Pole
-Blowsion pole pad
-RRP steering
-RRP riser bars
-RRP bar extensions
-Hand warmers
