- OH
The mods: 2007 superjet. True dual cooling. Factory B-pipe. ADA head 35mm. MSD enhancer. Ported intake. 135 main jet. 75 pilot. 95g spring. High speed screws out 1.25 turns. Low speed out 1.5 turns.
It runs. But about 80% of the time when you hammer the throttle it doesn’t take off. It doesn’t do anything. But 20% of the time it will launch without hesitation. Also I noticed when I fall off, it seems to continue to rev for a few seconds (but it is not just a high idle). Also when you quickly let off the throttle it seems to continue to rev.
Talked to Wammer and he said I need to upgrade the OEM spark plugs to NGK B8ES. But I won’t be able to try that out till Friday. I will try the new plugs and let you know. But in the meantime I was just wondering what you guys thought. Thanks!
