2002 SJ Build COMPLETED!!!
jeckert
Going backwards
Chicago
Here she is in all her glory! :booty:
Hull:
24-7 Hood Kit
24-7 carbon-fiber pole pad
24-7 carbon-fiber gas cap
24-7 hood hooks and hood latch
X-Metal handle pole
X-Metal steering/bars
X-Metal footholds
X-Metal scupper valve
Hydro-Turfed tray and rails
UMI throttle
UMI lever/perch
Custom painted red/black
Billet housing for MSD
Waterproof switch
Defoamed then waterproofed inside of tray and replaced with US composites 4 lbs foam
Reinforced bondline and hull with 1208 biaxel and carbon Kevlar
Hood Straps
Primer kit
Engine:
5mm Pro-tec Billet stroker crank Long rod 133mm
Lamey Power Valve cylinders
Wiseco Dominator piston
ADA racing Billet Girdled head
MSD Total Loss
Dual Novi Carbs
K&N Flame arrestors
R&D Intake manifold
Factory B pipe
X-Metal waterbox and side exhaust combo
Jet Works battery
CATS Trim System
TBM pump cone
Solas Concord modded prop (by Impros) w/ 3mm set back
Pro-tec ride plate
Worxs Intake Grate
