SOLD 1997 Superjet $5500 obo
1997 Yamaha Superjet
Carbon fiber surf reinforcement
Front and rear footholds
Front tubbies
UMI pole, Wamilton chin pad, Sato Engineering adjustable billet throttle
ODI LOCKONS!!!!!
Wamilton hood hooks and hood latch
Stock D-cut rideplate
R&D toploader intake grate
New watcon hood seal, turf, 1" under pad
Fresh PPG concept white, PWCgraphics 94-95 square nose gfx
New wear ring, motor mounts and midshaft bearing housing assembly
New s/s solenoid
Rule bilge w/ 3 way rotary switch
Limiter rope
62T engine
Factory pipe SJ mod exhaust
stock WB
Solas 13/17
Stock 38s, freshly rejet (135m, 70p, 2.0 n/s, 90g spring) High is 1-1/8 out, low is 1 out, will probably need some adjustment at the water.
Clean FL title $5500 obo
IMG_4996.JPGIMG_5004.JPGIMG_5008.JPGIMG_5018.JPGIMG_5020.JPGIMG_5026.JPGIMG_E5020.JPGIMG_E5029.JPGIMG_E5041.JPG
