1990 Jetmate with 1993 750 SS motor
I am using the 40mm Kiehin but kept the original Jetmate 650 exhaust system. Will an 800 SXR exhaust fit in the Jetmate hull without cutting the hull? What impeller would be best for this set-up?
We ran 33.7 mph with a sp 750, sxr carbs, and stock exhaust
My GPS reads 28 MPH with the current set-up. I will consider an impeller swap this winter. I may try a larger cooling hose and fittings to the overboard pisser. On a recent river trip I discovered that it burns about four gallons an hour.
stagesrt4
see ya out there
St Charles IL
over the years they change a lot of small details on the 750 engine
different heads, different cylinders, different cranks, different flywheels, different pistons, etc....
33 felt real fast in ours. Almost rolled it over a few times
subhard
TITS OR GTFO
anchorage ak
I can also only go 28 with a sp 750 and stock exhaust. @mydixiewtecked is yours defoamed? I'd love to get another 5mph. What prop are you running?
I prefer to keep the stock block for reliability but use reeds, carbs, exhaust and impellers to tweak performance.
