Theres one on eBay... No headpipe thoughYes but they also produced manifolds that were used with this pipe , it's the couch pipe like you are looking for , VXR , WRlll .
Yeah I saw it , that would have been an awesome deal if it was all there.Theres one on eBay... No headpipe though
I got a 62t cdi laying around was just gonna use that6m6 electronics will work on a 61x but the rev limit is really a bit too low for a 701, you could do the rev limiter mod to the CDI and make it work .
It will probably work but the 61x CDI and 62T CDI are different , A 61X CDI will definatly work with a 6M6 (650) statorI got a 62t cdi laying around was just gonna use that
my understanding is you can slap a 62t cdi in whatever so long as you jump one of the wires that have a gender mismatch, you only need to be careful with keeping stator matched with flywheelIt will probably work but the 61x CDI and 62T CDI are different , A 61X CDI will definatly work with a 6M6 (650) stator
certainly will never get good bottom end out of it.. I'm pretty confident I can make it sing on the top end though.As I said before a 650 is about the outer limit of what the stock pump can handle , you can put all of the HP in front of that pump that you want but it will never make it to the water.
I don't know if you have ever ridden one of these but it's not something you want to go that fast on, even with my meager 650 in mine , bone stock with a Protec pipe and a Skat stainless impeller it will get sideways with you and it will powerslide as long as you hold the throttle open.certainly will never get good bottom end out of it.. I'm pretty confident I can make it sing on the top end though.
Fx1 stock pump & 440/650 with a 550 pump are two of my favorites at the moment how bad can the 133 be.
And yeah I agree on wanting to stick with the 650 though.
I mentioned 6M6 to @Jr. I think he wanted to execute me on the spot![]()
we bought 4 of these things between buddies, all 500 so I've ridden them off and on the past few weeks... and yeah you hit the nail on the head initially gutless stock but the fun is definitely in there.I don't know if you have ever ridden one of these but it's not something you want to go that fast on, even with my meager 650 in mine , bone stock with a Protec pipe and a Skat stainless impeller it will get sideways with you and it will powerslide as long as you hold the throttle open.
The issue is if it ever hooks up it will spit you off instantly , the more power and pump you have the worse that particular issue is going to get , but hey I get it I did mine, you do you , I am not any kind of WJ expert by any means.
dmdThe difference between a 500 and a 650 in there is amazing , it's like a wild animal with some decent power.
I think I have a couple of spare 650 engines here , of course they would need to be taken apart and inspected and they have 30 year old crankshaft seals in them..
LPW got me covered for bores.I know Chris Newmiller still does them , not sure who else still does , Paul @ LPW maybe , he is close to you and he can defiantly bore your cylinders for you .
