- Central FL
i walk past them everyday
I used a skat reduction nozzle. During the fitting of my blowsion jd pump shoe I used the oem reduction nozzle from the jet pump. Part number 63M0 with W1 marking. I have a gp1100 nozzle part number 65U marking LS 1 both appear to be the same length and have the same mating surface to mounting hole measurement. I will pop the ride plate to see if I can read the wear ring and stator section.I too am waiting to put a 155 in my blaster. I have the whole pump and trim assembly out of a raider. I am still trying to find info on how the shoes mate to the pump, and whether to use the wide front bearing in the 155 pump, or the narrow bearing that would come in a 144mm pump.
I used a wb2 pump seal but it is not big enough to install like on the 144 pump so I cut if and stretched it around the wear ring lip. I was left with a 1" gap at the bottom that I silicone a piece of another pump seal in.
you sure on that chief? The bearings are similar, either will fit the 144mm driveshaft.Use the rear bearing out of the 144 and front bearing out of the 155 to make the shaft work in a 155 pump
yes I am aware of that. The 144 uses a 6205rs I believe, I dont remember the number off the 155 bearing.155 bearings are wider
