- HOLLAND MA.
Im in the market for a lower deck so i can get back into what i started. I plan on getting a epoxy primer/kev-glass flat water hull. I light the way Steve did his 08 set up (WCF). Id like to go the same route but have him do the epox prime vs gelcoat and a -2 or -3 chop. Im getting mixed reveiws on the 08 lower deck for flat water. Steve said he hasnt played with a chopped 08 yet and id be taking a chance. I can say this, I did a -4 chop on my buddys sxr and love the way it turned out. It sticks when u want and slides when u need it to. If i can get the sj 08 deck to feel close in ways were it will do both id be happy. Estimate hull weight is 75-80 lbs, Power plant is a 62t billit pv lamey 8mil. Also 12v mag pump, msd TL. My weight is 148 lbs. I did think of calling up Bobby with a shortened sxr set up but would like to stay with the SJ. I know Bob has a Sj in the works but dont know if i can wait. Any thoughts or reveiws on this subject would be a big help before i place a order with anybody.Thanks Ben
