05 Superjet don't start
hi there
my superjet don't start
the fuse in the CDI is ok
bilge pump run so the battery is ok
the motor don't crank
no noise
do you have any idea where I have to check ?
thanks
Open the ebox and arc the 2 contacts in the starter sulounoid. If it cranks, its either the sulonoid or the start switch. The start switch can be tested with a meter. Unplug the black/white wire harness going to the ebox also and try to hit the start button. Post back up and let us know.
SJBrit
Extraordinary Alien
Bradenton, FL
Good advice but do it in a different order to make it easier. First thing to check is always the start stop switch.
Step one: disconnect black and white wires at the in-line connector as stated. Press start and if it cranks then the kill switch side of the start stop switch isn't working.
Step two: if that doesn't work, then disconnect the brown and red wire connector and jumper across the terminals going into the e-box. If the motor cranks then the start switch side of the start stop switch isn't working.
Step three: of that doesn't work either then jumper the solenoid in the e-bopx as stated. If it cranks you have a bad solenoid, if not then you either have a bad starter or bad cables. Check the cable connections to the starter - make sure they are clean and tight.
ok so I did it:
And it cranks no problem
so it's a bad kill switch
how I repair it ?
do I have to replace all the start stop switch module or ?
and where I can buy it brand new if possible
thanks for the input
hi guys, update on the problem
I putted dielectric grease in the plug contact ( black and white wire ) and it solved the problem the ski run great
cool, it's just that !
thanks
