Fuel line issues
So this all started when I ended up with a set of purple fuel lines biz fuel lines. I won't go into how that came to be since it is irrelevant and several people here know already. I remember reading several posts about how these lines were Alcohol fuel compatible and how UV stabilizers had been added to prevent premature cracking and hardening.My lines are now hard , horribly discolored and no longer anything resembling purple.
At any rate I installed them on my X2, now the X2 is my backup boat so it sits around quite a bit, I have no fuel petcock, just a pickup , a vent and a return, probably 8 ft of fuel line max. I have a front pickup that I modded from a Seadoo and a clunk on the end of the pickup. So I get the ski out first time this year and it doesn't run right, I ended up pulling the carb at the ramp and there was gunk in the filter, not really a problem, I cleaned the filter and rode the rest of the day.
About a month later I meet up with a guy off the board who wants to ride an X2, I had siphoned all the gas out of the X2 the day before and the tank was spotless, fresh gas was installed and I fired it up. When I backed it in at the ramp and fired it up it sounded funny,there was a long no wake zone at this place and as soon as I exited the no wake zone I hit the gas and it fell flat on its face, I turned around and barely made it back to the boat ramp. Back in the carb I go and the internal filter is stopped up again with greyish looking gunk, I clean it outs reinstall the carb and go back through the no wake zone, I hit the gas and it takes off for a split second and falls flat on its face again. I baby it back to the ramp and load it back on the trailer.
So today I finally get around to yanking the fuel lines, grey gunk is all inside the filter and clogging up the internal filter, the hole on the return is stopped completely up and there is green goo around all the brass fittings on the carb. The return fitting has grey gunk all inside it as does the pulse fitting, you guessed it I used a piece of the purple fuel line for the pulse line.
Now I am not calling anyone out here but with the clunk installed on the end of the pickup the gunk had to have come from inside the fuel lines, I know the tank was spotlessly clean as was the fuel I put in it, it didn't come from the filter, this leaves the fuel lines. I rebuild carbs and replace fuel lines here damn near every day, the greyish gunk and green goo on the fittings looks remarkably similar to the crap I see inside the Seadoo carbs, the inside of the grey fuel lines also looks very similar to the material the fuel lines biz stuff is made of. I now have Gates green stripe 1/4 automotive fuel line on my ski, thats how its going to stay, the little amount of bling the lines provided is not worth the trouble they caused me.
Bottom line if you are having weird running problems with your ski and you are running these lines you might want to take a look inside the carbs, you may find your answer there.
tor*p*do
Squarenose FTW
NW NC
Terry - just rip all that cr@p out!
go get some plain old black fuel line from
AutoZone or Advance
Done!
AutoZone or Advance
Done!
Already did today ,Gates green stripe baby, I buy it by the 25ft roll for the Seadoos, never again. This thread is more for those that think they want those lines on their ski , think twice, ride longer.
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
I was wondering how long it would be before threads about this popped up. If it looks like poop... and smells like poop... then that :):):):) is poop. One question tho, why is this not in the negative feedback forum? This thread is a little incognito to really get the message out about this garbage.
McDog
Other Administrator
Staff member
South Florida
No doubt they discolor and harden but I've never had the goo. Not saying you didn't or that they don't, just that I've never experienced it. That sucks. The tygon lines I have used hardened too. Somebody needs to post a link for cheap black OEM type fuel line.
QuickMick
API 1104 AWS CWI
I've had them on my ski for 18 months.
They've discolored, they've hardened - but the gunk problem I have not experienced.
X2. The fuel line bizz I did NOT use and still have in the box now has some type of oily residue on the outside of the entire length. This happened on the Orange and Blue line I have.
I have some RIVA blue Primer line that has been on my ski for over a year, it is still soft but has lost some color with no oil on the outside.
Im not sure where Riva is getting their fuel line. They have RIVA ink stamped on the OD all the way down the full length.
OCD Solutions
Rentz, GA
I stripped out all my colored lines as well, I didn't have the gunk issue but I did have swelling, leakage, hardening and discoloration issues with mine. I replaced it with some black fuel line from Ace Home Hardware that is supposed to be ethanol rated. So far I am pretty happy with it and have no issues.
JSS is still in the process of doing a huge buy on bulk high quality fuel line. When I spoke to him last week he still hadn't heard back on a delivery date. Knowing John it will be worth the wait.
