FX-1 will a 750 sxi pump fit a fx1
will my old kawasaki 750 sxi pump fit a yamaha fx1 i am looking at buying a fx1 and i am breaking a kawasaki 750 sxi and dont want to sell the pump if it will fit the fx1 will i see many gains if it will
i would rather keep i fella thanks for the offer thoe its only i already have it so its just easier to keep my one i am a metal worker so i would be able to sort it quick mate
tom21
havin fun
clearwater FL
anything can be made to work, its just how much effort do you want to expend doing it? and then you have a kawi pump which is not the best setup IMO. its harder to align and not a great supply of parts or props. much easier to a yami setup. I understand you have the parts, I would still not do it. again thats just me. I know of some that went the kawi route and wish they had not. cheers
tom21
havin fun
clearwater FL
not at all. you will need to cut the mount tabs off the wear ring and reweld in the correct spot. a little grinding on the nozzle tabs, lots of grinding to clear the rideplate, and more to open the pump shoe or install the 144 shoe is better but more work and money. its been covered a good amount of times with pics and such.
dfw
The Kawi conversion is less work than installing a 144 and getting it to work as well as does in a Suprtjet.
tom21
havin fun
clearwater FL
I have read all the threads, and I see lots of glass work. how is that easier? I see nowhere on how to correctly line up the pump. just sticking it in is not gonna cut it. with the yami setup the shaft can be centered to the hole in the hull and shimmed to be centered. as well as the intermediate shaft and the motor. depending on the slop on your shaft and prop you can be off by quite a bit and then you have problems. add in the fact that the tray is now modded and if done incorrectly possibly not level. makes the problem worse.
I understand its easy to gloss over the little things, but then its the little things that get ya.
people are gonna do what they are gonna do but in the interest of HELPING each other I want to make sure to provide the important details to make sure nobody regrets their decision with either install. its not what I like vs what you like (sj vs kawi age old grudge) its about the best way to do it. both paths have merit and both have hurdles. modding a wear ring seems a little less work then tray and bearings and no definite way to align it.
would the one blowsion do give me big benifits over the other two that have been suggested and woul it be just straight bolt on or do i need to buy other parts
I can't see why there is more problem centering the kawi than the yam .
if you stick an half motor with coupler you will be able to center all setup yam or kawi . Don't use stock coupler for that but a new billet set.
All the mesures for level are here . I was off for the rear of the pump and just add stock shims ...
No yamy kawy war here i just find the work to fit the ride plate easier on the kawi .
the WaTeRhAwK
fryin' up a/m electrics..
okc
10mm has an FX-1 with a 701, B pipe, and stock pump. he says it has an 18/24 impeller in it and says it jumps out of the water so bad he can barely hang onto it. :dunno:
the WaTeRhAwK
okc
its all relative - I don't think he's ridden a big pump ski
he says he had it out with some superjets and an sx-r, riding them also for comparison, and he states his fx blew them away on the bottom. I thought an 18/24 would be way too much prop for that setup i/e mostly stock 701, but hull is lighter? :dunno: he says it's almost too much for him to handle.
the WaTeRhAwK
okc
I've ridden a 122mm FX-1 and 144mm FX-1 side by side - huge difference in low end response. The midrange and top end can be really good with either pump
but how does he get such good low end performance with such a high pitch prop on a mostly stock 701? is it because the pump is so small?
I mean, my 400/750 conversion will rip off the bottom like that and has a 19 degree prop in a 440 pump, but 18/24 seems like a lot of pitch to me to be getting that kind of low end.
