- Tuscaloosa, AL
yes, it is possible to go too slow............... I dont do subs much anymore, just dont like them I guess............. but here is a hint, Gas and hop at the same time, as you leave the water, let off the gas, lift your feet to the underside of your butt (Bending your knees like you are squatting), as you enter the water and go under, you can drag a leg to act as a rudder also (old 550 trick) If that does not work, try the same actions and check to see if you are lowering the pole to the hood, if not, focus on lower the pole, by doing this you are forcing the nose down, also, as you are bending your knees and pulling up with your feet, tuck your upper body over the bars
