installing footholds for the first time
I just got a pair of footholds for my sn and was wondering on some tips for instilation. Also do I just need to use the 3M 5200 to secure them or do I need to glass the seams as well? The more information the better for me so I can get out and start riding.
Ryan
fixing to do mine for the first time as well, everyone on here uses 3m 5200, some use epoxy, but definately need to glass the seems to make theme stonger and make theme water tight, and also need some 2 part foam
Thickened epoxy to secure them, stainless screws or rivets to hold them in place, then atleast 1 layer of 8 oz glass over top. Install them with 5200 and I don't think they'd hold up more than a couple rides.
SJBrit
Extraordinary Alien
Bradenton, FL
Nonono! Lot's of things thicken epoxy for sure, but many weaken it. There are thickeners called "fairing" thickeners which leave an easily sandable mixture for surface finishing. For footholds you need a thickener that adds strength like cabosil, not powder or microballoons or anything like that.
I used the wamiltons instructions too with my old SN. I removed the screws vise grind them off. I used West Systems epoxy and the high density filler they have. Also laid a piece of cloth and watery epoxy in the tray. I felt it was a shot in the dark given my experience, but those are like 3rd grader instructions, so it worked perfect!! This time I will using the same instructions and will be putting some biax down for the floor and running polystyrene.
jerzyjet
-enter user title here-
Dirty Jerz
what about any type of of automobile 2 part epoxy. My work has tons of stuff by crest east coast. We have a 2 part epoxy panel bonder that with stands up to 35,000 PSI pressure. We used it to bond car roofs and quater panels then mig the factory spot welds. i got holds from tom21 and may start tomorrow.
jerzyjet
Dirty Jerz
I got US Comp 3:1 epoxy resin. What else would I need to secure the holds to my SJ. I am guessing the 3:1 epoxy resin is used for the mat glass, but is it strong enough to glue my holds to the hull? Also which type foam is best? i see USComp has several strength foams to pick from. I only want to make one order and make sure I have EVERYTHING I NEED. Thank you
SJBrit
Extraordinary Alien
Bradenton, FL
You need some cabosil to thicken the resin, some screws or rivets to clamp the holds down while the resin cures (you can leave those in or take them out - doesn't matter), some 8oz cloth to reinforce over the seems, and 4lb foam to fill. You might want to think about reinforcing the tray between the holds while you are at it, and 1708 biax is great for that, or just build up a few layers of 8oz.
jerzyjet
Dirty Jerz
cool thanks man, I got some SS screws holding em place now, but didnt want to jump to epoxyin them in till i knew what i needed.
SJBrit
Extraordinary Alien
Bradenton, FL
No problem. Make sure the resin is nice and thick to bond them in (it takes a surprising amount of cabosil to achieve that - it needs to be like peanut butter ) and apply liberally around the seem. You want to see it oozing out everywhere when you tighten the screws down. Then wipe the excess off immediately but leave a little oozage all around the outside. Check for any air gaps and goop some more thickened resin in there if necessary. You end up wasting quite a bit, but that's better than leaking or cracking later. You can put the 8oz over the edges right away - you don't have to wait for the thickened epoxy to cure and it's actually stronger if you don't. I cut it into strips about 3 or 4 inches wide and patch my way around the edge. When you put the cloth over the edge, you can squish it down onto the oozage, and that forms a nice chamfer to help the turf bond. I'll sketch a pic and post it up in a couple of minutes.
