wb800.so how do the pumps compare if your running them with sim motor setups,Id really like to ride those tj setups if they are truly setup for freeride?
steve.. why would you run a 144 stocker with a r&d cone if you have a 148 mag that worked well with a 701,it would work even better with a PV 860,that motor is pretty linear,it would prolly be sick with the mag in the surf,let us know if you try it out.
josh,surprised lucas runs a dry pipe if that is the case,arent you guys all about low end for freeride and freestyle anyway.hard to imagine a 1000cc motor with not alot of low end with ANY pipe really
Aron..good analogy,I went through that very thing with a auto big single sup and a stock twin 6 spd.stocker pump = street tires,mag pump = drag radials as well? sent you a pm also
