advice on buying used superjet
fwi
X-
Cape Coral FL,
I thought I had a deal on a primo 92, but, when faced with the prospect of separating himself from it, the seller decided he didn't want to sell after all!!
So now I found another, this one is a 95, totally stock squarenose, looks fair, no cracks and the price is less than $1500.
When I lifted the hood, we found the hull was half full of water! Rain? maybe. The owner says he only used it once about 2 months ago, so we dump the water out of it,(it smelled musty like its been there awhile) but it fired up, no problem.
I am wondering if this water may have caused any kind of internal damage? I am going to do a compression check on it, what should it be, 134-150?
Anything else I should look for? Thanks for your inputs.
GB
Do a compression check.
If it was only half-full of water, it should be fine.
Of course, there could be water in the flywheel area, but I doubt it.
1500 is a good price. Talk him down on account of the water.
Shonuff
I've got the glow
Memphis
Change the plugs, rebuild the carb, replace the fuel filters, run some synthetic through it, and you're fine. $50 total. :woot:
meatball
User Title Unavailable
Maryland
If its a cheap gauge, try and check it on something that you KNOW the compression of so you dont mislead yourself. The compression should be 150 though in both cylinders. Within a few psi of eachother. Does this come with a trailer? Depending on cosmetic condition, 1500 is a pretty good deal. I paid 1400 for my 91 650 SJ with a dual standup trailer. Talk a few dollars off for water. Mention it couldof gotten into the flyhweel and destroyed the bendix/flywheel/stator (unlikely but possible)
