SJBrit
Extraordinary Alien
- Bradenton, FL
JB weld?
My thoughts too.
Where's the spacer I made for this engine? Did you not buy the complete exhaust system for that 8mm stroker? That engine was all complete and fitted, did TEM not sell it to you?
Damn I got a brand new manifold and B headpipe all done just setting on the shelf ready to go with the spacer, gaskets and bored outlet to match that engine! (Our new low profile PV don't need any modification for the 'B pipe to fit, so not using it) Are you hurting for $ that bad to go through all this pain?
Chuck
Jet skis=money pit...A gateway to going broke!
By the time you add 2 gaskets you don't need that much grinding to get it to clear, weld it up and you'll be fine, did you bore out your manifold and port out the headpipe to match the spacer I.D. size?
Tem is such a quak, there was no reason for him to break it up and make it hard on you! He doesn't even have any PV engine to use it on*****!
Chuck
Right now the weather is hot, the credit card full, and it's time to ride! :highhorse:
That was my first thought, but how much pressure is in there? Think it'll hold?
