Will an 05 SXR ignition work on an older 750 setup?
SXR-FOREVER
Finally Flippin
I think you can...
I ran a stator out of a '92 750 in my SXR ALL last summer. You just dont use 2 of the wires. Not sure which ones, I can look if need be. Flywheel are the exact same too...
Scorn800
Ride for life
North NJ
I think you can...
Your right about using a back dated stator (only use the pick up trigger wires) with the new 04 & up CDI & electrical box.
BUT you can't use a 05 cdi with old style electrical system. The cdi will not plug in to the old harness.
isn't there a harness that you can buy just for that?
i thought i had read about this a couple years back.it was cheap too.
