- United States
Lets see the trailers you haul your Jet ski with.
, xm, cd player, ipod with 4 6 1/2" speakers that sits in a custom molded fiberglass sealed mount. 500 watt alpine amp with a custom molded fiberglass box, that has a competition 12" sub. i also installed a marine wired remote outside the trailer. 110 outlets inside and out, a custom mounted air compressor under the frame of the trailer, that has a 5 gallon tank. it also has air spickets inside and out. i also used it at the races for a week and it maintained its own power with out needing to plug into a generator. it has a 110 battery charger that i installed and have never needed to plug it in. let me know what you think and if you have any ideas that will make this better. Thanks
Mine have been posted here a few times but here's one.
Fuel, oil and spare, spray lubes go into the box (I can carry 15 Gal) as well as all the wet riding gear at the end of the day.
I'm not holding out nutin, it's all been posted on here before.
Here it is again.
:bigok:
Here it is again.
:bigok:
wow layne awesome. make sure you check the bearing out too.
