need to block of main fual line
Feed the reserve to the carb and use the main line as a return from the carb(s).
Block of the regular return line nipple with a short hose with an appropriately sized bolt in the end and ziptie it. Probably redneck, but it's served me well for the past five years.
Motorheads5
Livin the generation gap
ketchikan alaska
you can get vacuum plug's at an autopart's store that will fit right over the nipple that stick's out of the fuel tank. That would be a sanitary way of plugging it off.
onesojourner
I use a thumb throttle.
springfield, mo
I tried the bolt thing on the main line this year and it actually leaks just a bit no matter how tight the clamp was, but I guess its no big deal if its on the pulse fitting or something.
