- calgary alberta
Can someone explain to me the diff between a mod, limited and any other type of pipe that might be available? The pros and cons of either.
If your going to build a XS1000 for flatwater you going to use the Power Factor Dry Pipe! Same set up Lucas, Pat, Stoyer, etc are running.
Brian at Thrust has a PFP on his Dasa powered Rickter, nice set up for Flatwater.
