the WaTeRhAwK
fryin' up a/m electrics..
- okc
this is funny....
"The Quasiturbine allows important energy savings without having pretensions of a better thermodynamic performance than any other engine (remember that 4-stroke pistons are propulsive only 19% of the time, and dragging the rest 81% of the time). In fact, the ability of the Quasiturbine to generate a strong and continuous torque at low rpm permits in numerous applications including transportation, the suppression of the heavy and costly gearbox that consumes between 8 and 12 % of the energy. Furthermore, the best power to weight ratio of the Quasiturbine (to which the flywheel suppression contributes) gives rise to lighter vehicles (also due to the suppression of the gearbox) and fuel cost efficiency. The fact that the Quasiturbine does not require energy consuming peripherals (pumps, camshafts, push rods, valves...) also constitutes a gain at the level of energy efficiency. (See High-tech for the detonation mode). Furthermore, the rapid expansion volume just after T.D.C. allows to extract more energy from the initial hot gas with 3 advantages: thermodynamic exhaust cool down, less heat transferred to the engine bloc, and less NOx production. Energy efficiency is related to all the following"
http://quasiturbine.promci.qc.ca/ETheoryQTSpecifics.htm
so, uhmm... would you guys like a little seasoning, or salt and pepper with your words, or would you just prefer to eat them plain and without merit as they actually are?
