- Houston/Galveston
Well I put my ski together after reinforcement, and the engine would turn over, but not fire off. I pulled the plugs and looked to me that they were flooded. Checked for spark and I had good spark. Cleaned the plugs and tried again, nada. This went on a few more times, and even changing to new plugs. Im thinking this mofo has to fire off, good compression, ignition and fuel = a running motor (timing is good) JSS stator and coil so Im thinking im good to go.
Once more cleaned the plugs but this time I sprayed some carb and choke cleaner in the plug holes and BAMN!! Fired right up.
Now im thinking WTF?? Fuel is about 4 months old.
What is/was the problem? Anyone had this happen to them?
I guess I will remove the fuel and blend in some fresh fuel with the old, there was only about 2 gallons or less of the old fuel.
