Those of you that set set up hand warmers on you skis could you post some pics. If possible with the handle pole pad off. What Im curious about is how you set up the Tee and mount the tubes to stay in place and spray on the grips. For those saying huh? Its a setup running an extra cooling tube up through the handle pole and spraying the warm motor water on the grips to keep your hands warm.
thanks,
Brad
thanks,
Brad
