- Little Rock Arkansas
How do you get it out?
Thanks
Shawn
Thanks
Shawn
could you show more pics of the shoe? I'm going to grind mine out to ~144mm and I'm curious which sections will break through to air pockets
if you are going to go that route take the shoe out and fill it with epoxy and then glue it back in the hull. Then grind it away. It will be paper thin. Picture below is the pump seal from a 144 pump against a fx1 pump shoe.
I just smacked it with a rubber mallet then started to pry a little with a prybar.
In all honesty the best way is the 650 pump or to make a sj shoe fit. If you break yours you can have mine for shipping if you want, i have no need for it.
after all you are doing all this work might as well do it right in the first place.
is the SJ pump shoe a drop in?
not yet - I think I'm going to first tackle my X2 project this winter
