heres how our x2's are set up.....
I have my F/A turned forward like crab's but my throttle cable is really tweeked hard against the head on the 750 motor. maybe the 750 manifold angles the carb more towards the motor? Anyway, I just bought a cheap 550 throttle cable to pull from the bottom, not from the top, to fix that issue.
Also, if you take of the OEM mikuni throttle 'wheel' and turn it over & upside down you can still use it and not the aftermerket throttle wheel. But that purple wheel sure looks sharp!
